any strait wt. motor oil works. the last time i changed my fork oil i used 30 wt. about 4or 5 years ago. no problems with it. if you want a softer ride 10 or 20 wt. will do.
Auto trans fluid in my 02 FLH but some times i think it is on the soft side, No not really, that is only when I am ridding it like a Buell. Its good. Don over and out>>>>>
Im going to change my fork oil to Spectro 40wt fork oil. I have noticed the Screamin Eagle fork oil is still a little thin for my needs with this trike setup. The front end takes some abuse in cornering now since I cant lean like I use to riding 2 wheels up
If what a little stiffer ride use the Screamin Eagle otherwise use the Type E (OEM fork oil). I prefer the Screamin Eagle fork oil for my bagger and Type E for the cartridge type forks on my Dyan T-sport
Im following your lead. I picked up the 40wt oil. Im finally getting the front end back together. I had a hell of a time gettin the screw caps back into the tubes with the spring in there. im not a big man. Im going to the chiropractors tomorrow. If a front end seal ever goes again. Its going to the shop!
