Windshield Cracking
Windshield Cracking
'05 EGC. In the last week I've had a flat 8" & a pre-formed 10" windshield (both acrylic after-market) crack at the mounting screws. The 8" cracket at the left side screw, then totally split in two at the center screw location after the screw fell out. The 10" has cracked at both the left & right screw locations, after I installed it with 1/32" rubber tape along both sides at the bottom. I'm treading the fine line of tightening the screws enough to keep them from falling out (I thought) & tightening to the point of pulling the threaded inserts out of the inner fairing plastic (it happened twice). I have switched these windshields several times over the last 2 years but have never had this problem. I slowly tighten the screws evenly while I wiggle the windshield to make sure it's seated. I Am I missing something?
Gregm
Gregm
The windshields will crack if you have the screws too tight. You are only suppose to lightly snug the screws that clamp the windshield between the inner and out fairings. If you dog them down real tight the windshileds will crack after riding a short period of time. I've even had mine replaced way too tight at the Harley Dealerships. If anyone ever has your fairing off always check to see if they have over torqued these screws.
Hope this helps.
Hope this helps.
Been there, done that. I change my windscreens out about once a week depending on conditions (I run a 6", 8", and 10" Fastaire). I've had the screws fall out (I always keep a spare now) because I'm careful not to over-tighten them. Still, I noticed a crack in my 6" Fastaire screen last week.
