It's not a freak'n wobble!
#81
Ratcat and Spizzy wont have any issues, you have brand new bikes. Their not even broke in yet...LOL You shouldnt have these issues with the upgraded frames. The 1999 Ultra I ride has 3 week spots: swing arm, chain tensioners, an M&M fuel injection (works great for me). The brace is a cheap fix. You have better electronics, frame and swingarm and fuel injection along with a paper mache crank... I would doubt you'll ever have the issue...
#82
It may not be a wobble but I experienced a pretty violent occilation of the handle bars on my RG when riding a somewhat spirited pace through Atlanta a while back . The bike went through 2 lanes and on to the shoulder before I got it under control again. I learned a valuable lesson about how critical the adjustment of your steering head bearings is. I adjusted the steering bearings and despite the swingarm bushings being slightly worn there was no more wobble/occilation but I do agree that a brace could'nt hurt. Ride Safe out there!
p.s. The hand of God was probably a big help too!
#83
Finally we have some clear insight into the cause, or rather the bogus claims, of bagger wobble. The so called problem is only in people heads and doesn't really exist. The solution is to have everyone ride the same bike (Must be a, '08 black RKC), on the same roads, with the same options (bars, pipes, a/c, chrome bits), at the same speeds, at the same temperatures, and you must all have the same miles on your bike. Everyone must also be the same weight, height and hair color. You also have to smoke the same smokes, wear the same leathers and boots. You must ride in the same wind conditions and above all else, you must drink Tequilla (The brand is important.).
Gees, I thought it was just me. Thanks for the help - I feel safer now.
Can you guys also help me with my truck? I don't get the same gas mileage as you do.
#84
#85
Just unscrew the radiator cap, remove the vehicle and replace with a Dodge...
#86
#87
#88
Okay, I am new here, and new to HD's. From what I am gathering is that pre 09 there is a slight "wobble" problem. Some feel it worse than others. What did HD do to fix said problem for the 09's? It sounds to me as if they put in beefier bushings on the swing arms. That sounds like it would make sense. I guess my question is why not replace your bushings and fix the problem proper instead of putting a band aid on by putting a brace on the bike. Some one said earlier that you may be looking at cracked frames later on. That might be a bit extremem but you are putting preasure on a spot on the frame that was not designed to accept said preasure. If it were me, I think that I would rather fix the problem right and be done with it. Just one less thing to worry about. Just my .02 cents.
Jim
Jim
#89
In the software /IT industry this would called a "third party opportunity" meaning let another company design and sell a product to take care of an issue that isn't important enough for a solution by the company that released it.
I think many of us expect complete perfection from our HDs as they cost so much and have been around so long you'd think they would have worked out all the kinks. Nothing's perfect...
#90
Thanks for the positive feedback guys.
Type in "bagger wobble" in google and you'll start to see how pay per click ads and banner ads for brace suppliers work. It shows that this whole "wobble" thing has taken a life of its own, kinda like when 60 Minutes did that whole Audi "unintended acceleration" thing. Nothing was ever proven, there wasn't a hint of evidence, but it almost ruined Audi and it's been estimated that they took 15 years to recover.
