Best Center Stand
What about an 09 lowered both front and rear? From what I see on your website you have stock height and rear lowered for 09s but lowered both front and rear only for 08 and earlier. My 09 Classic has the shorter air shocks in back and the lowering kit on the front end - H-D parts in both cases.
Thanks
Thanks
Thanks
Thanks
On the pre-09 models the lowered in the front and rear stand is only 3/16ths inch shorter than the one for the lowered in the rear only model. As the front is quite a bit further from the pivot point of my stand it effects the height of the stand much less than lowering the rear.
I put the Wheeldock on last summer. I use it all the time and it is especially handy when loading the bags, but especially when washing the bike.
If you're going to lower the bike, I would wait to buy one. The Wheeldock site offers several choices for height.
The center stand is so easy to operate, easier than any Jap bike I ever had!
Bob
Also, the Wheeldock for '09 models is even easier to install as it has only one bolt! As for scraping during leans... if it does, it is because you are already on the ground! Another point to consider is that the '09 toruing frame gives you an additional 1 degree of lean angle, and after talking with Rod at Wheeldock, you still will not scrape the stand. This is a welded unit that is elegent in it's simplicity and is available for '09 models today.
Bob
Bob
The Wheel dock is about a 5 minute install.
How long does it takes you to screw on two nuts and tighten?
It is not adjustable though.
If I had to do it again, I would buy the adjustable HD one.
Wheel dock: $289
http://www.wheeldock.com/
HD: $329.95
HD part number: 91573-06
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Zanotti HD will sell it for $276, plus $19.79 S&H, for a total of $295.79
https://www.zanottimotor.com/
Wheel dock: $289
HD: $329.95
