Securing GPS to Mount
Yes it can. I made one last year and posted the pictures here. It consisted of a aluminum split collar I bought from McMastercarr. It clamped right on the handlebar by the left grip. To I welded a U shaped of 3/8 aluminum rod. The exposed end was tapped 1/4-20, to which I cut off the ball from the suction mount... odd size ball... and tapped it also. added a set screw and polished the whole thing. I got about $15 in it. I'm not good a giving links so do a search in my published stuff and it's there.https://www.hdforums.com/forum/showt...ighlight=mount
I have a Ram Mount and it works fine. I leave the ball mounted to the handle bars down by the fairing and you hardly notice it. I have a Ram suction cup with a ball on the end on the car and just move the GPS where I need it.
Go to www.powerlet.com They have lots of choices and I'm sure you will find something you're like that looks good. I purchased a mount for the handlebars that has a taped hole for the ball mount and a plug to plug in the GPS. It's small and looks good when not in use. I take ball off when not using the GPS. Sorry no pics.
The ball mount is available at your Harley dealer. the GPS mount is available from Garmin.
or at the GPS Store on line. cut and paste the following url into your brouser.
http://www.thegpsstore.com/Garmin-Mo...-P224C137.aspx
I guess I should have been more clear. I have a RAM mount set-up for the GPS unit but I know the friction mount ball will not stay in the GPS unit due to vibrations & bumps. I'm looking for ideas on how to secure the unit to the ball mount.
Here's a picture of what I have, it's the bottom unit...
http://www.e-mount.com/page_results.php?uid=764
Pictures were on the old site and not readable here.....
