road glide head light ,??????
My 07 road glide, has what appears to be dust or some type of overspray inside the head light assemblies. Not the plastic cover, but inside the head light. The out side of the light are clean and smooth.
Anyone else have this issue, or suggestions on how to clean them out????
Even the chrome relfector part of the lifht is dull and dingy.
thanks ....
thanks ....
Sounds like what the EG spots do from time-to-time. Are they sealed beam or elements? If they are elements, pull em and clean the insides with (vinegar?....not alcohol as it will bugger up the reflective coating). Dry *thoroughly* before re-assembly.
edit: looking at the online catalog, the RG appears to use replaceable halogen bulb (elements). So you should be able to clean the lenses and reflector optics.
