2" pull back Bars on 08 Ultra
Soldering tips
The clothes pin tool os a great idea. It is important to keep the wires from moving relative to each other as the solder cools or you can get a "cold joint" that has low conductance. You could also glue 2 small pieces of aluminum or copper to each clothes pin to act as a heat sink if the insulation is being discolored by the soldering iron.
If you put a small drop of silicone sealant on the joint after it cools and before sliding on the shrink tube, it will extrude out as the shrink tubing shrinks and form a prefect watertight joint. It can also add a little more abrasion resistance over the joint in a high vibration environment like an idling Harley.
crash12888: Great Post. Perfect timing. I just took delivery of a set of Chubby Wild One 575's. They appear to be very similar in dimension to the HD pullbacks just a little pricier ($200) but for chrome vs stainless and the larger (1 1/4") cross section they appear to be in line. Looking forward to installing them.
Thanks again for the help.
Thanks Bertk, Hope I havent lead anyone down the wrong path yet. Gotta love this site.
I Just went out and sat on my bike and can see the area where the fairing mirrors would be on the SG but cant say if vision would be blocked by arm or hands.
Will these fit with ABS models?
Hello Crash
I enjoyed your post about installing the 56176-08 2" pullback bars. When I saw the product online, it doesn't say that they are incompatible with ABS equipped bikes. But when I went down to the local dealer, it said on the box and the '09 catalog that they are not compatible with ABS bikes. I am confused!!!
Is your bike equipped with ABS? Or has anyone tried fitting them to an ABS bike?
Thanks,
Quint
Thanks,
Quint
Cosmic Razorback
2014-2023 Touring Models
03-11-2019 04:34 PM
DR. V-TWIN
10-29-2010 08:41 AM
