Dead battery?
if you are running stock, then after you replace your battery, there may be a 'slight' learning period for your ecm, but that is usually not terribly noticeable.
if you have a pciii, then the map is stored in the pciii and is not affected by the battery. i would assume the fuelpack, and other aftermarket black boxes are the same, but i could not say for sure.
you would also have to reset your clock.
martin10
09-05-2014 11:09 AM
Tesla_HV
04-26-2013 11:08 AM
KBFXDLI
10-29-2012 08:41 PM
TheGuyWhoPosted
02-23-2008 08:23 PM
