How to wire heated gloves?
I've never used any heated gear, getting ready to buy some Gerbing gloves if I can find them. I understand that my '09 SG has a plug under the seat, do the gloves come with a long cord? Do you run it from your beltline under your jacket, through the jacket sleeves to your hands? Where do you put the thermostat control? Thanks
The gloves (vest, jacket liner whatever) all come with a pig tail that connects to your battery. Black to Ground, Red to positive... simple as can be... I have mine going up the slot my back rest goes through... I spent last winter with the end coming out of the front of the seat. Either way, I can tuck the pigtail out of sight when I'm not using it
for a20% discount check out http://www.grandprixmotorsports.com/default.asp
edited to add... you only need the ONE pig tail for the rider... I'd add a second, if i was going to carry a passenger, and she had electric gear
John: After many years I finally gave in to electric, great choice. Like others, I have the pigtail wired to the battery and have it come out at the front of the seat. I use the Tourmaster vest and it plugs in at the lower left waist, the bad news it has a bulky temp controller. When I use the gloves, I plug the gloves into the battery pigtail, and then the vest into the extra connection on the gloves. Again the bad news is the wiring is bulky on the gloves... the temp controller is not bad on the gloves, the wires are a "jungle"... I just lay the wires on the tank and do not try to hide the fact I am riding electric....
Later
Hogback
Later
Hogback
I use the Jacket liner and the Gloves best investment and has extended my riding season here in NY through the winter as long as the roads are dry we ride. I got advise from someone on the fourm and ran my lead up through were the back rest is, when not in use tuck it in and out of site works real nice.
