Tri-Glide
Old 11-19-2008 | 02:04 PM
lschultz's Avatar
lschultz
Over on VTwinForum OldMsacko just bought him one it is under the thread Saw the new HD Trike Today. He has a picture of it over there I will try to put it on here but I am a puter idiot so I don't know if it will work.
Old 11-19-2008 | 03:07 PM
Geoff's Avatar
Geoff
The Tri-Glide Ultra is nice, but pricey. Electra Glide trike conversions made by Lehman before they enterd the agreement with Harley were less expensive. You might check and see if they're still available.
http://www.stockmildtowild.com/lehman_trikes.htm
Old 11-19-2008 | 03:27 PM
rc9636's Avatar
rc9636
By all means ride one before you even think about buying one. My wife loves her trike
but yes it does require upper body strenght as you have to steer it through the turns.
And if your wife has back problems the side to side jarring that you get with a trike going
over bumps may bother her. If they are selling a tri glide for over 30K it's priced over
MSRP (which may be likely for a while considering each dealer is only getting 3 ).
Old 11-19-2008 | 03:43 PM
bonzi88's Avatar
bonzi88
Had a discussuion with a buddy about Harley trike conversions. He's been shopping for a trike for quite a while. He said that the quality of HD's conversion is quite low compared to other conversions...as if HD took the lowest bid..
Don't quote me on this.
Best to talk to a unbiased trike converter as to quality of differant conversions. U can add reverse & and other goodies and still be money ahead.
Old 11-19-2008 | 04:34 PM
Blacklion213's Avatar
Blacklion213
Default re:Tri-Glide
I saw one, I rode one and I wasn't impressed. The 103c.i. isn't enough the way Harley delivers them. The trike body is more piece meal than the Lehman (they produce the parts and assemble them for Harley).
You might want to look into a Lehman Conversion on a FLHTCU instead or a sidecar. If you are thinking trike remember some states require a separate license for trikes/sidecars. Insurance is another problem. If your wife is going to drive the trike you might want to ask about a rake on the triple tree (power steering for trikes).
Good luck.
Old 11-19-2008 | 04:43 PM
Casper's Avatar
Casper
I still like the California SideCar better....
Old 11-19-2008 | 06:09 PM
Gutman's Avatar
Gutman
Lehman, DFT and other kits run around $9000.00 without wheel/tires/paint. Couple that with the price of a new bike the Harley is cheaper and you get a 2 year Warranty. That still doesn't have the raked trees the HD does. the Champion trees run $1200.00. You couldn't convert a new bike cheaper, probably could used or existing model. As for the upper body strength, I have ridden trikes with the stock trees, Champion raked trees and Harleys. The difference is the raked trees feel like power steering compared to the stock (manual). The "piece meal (?)" is a good thing because if you damage a fender you do not have to replace or repair the whole body, you can replace/repair the fender and so forth. Fiesty 1 is hearing the compensator pack and not the lack of automatic chain adjuster. He has a 2005 so the tranny and final ratio are different requiring a lower gear to bring RPM's up. The Quality is not low quality in my opinion. I do believe the DFT's handle better and are better quality, but at a much higher price. As for cost $29,995.00 is for black with no reverse, $31,994.00 is for pearl/sun-glo with no reverse. Cruise is standard, reverse is $1195.00 and security is $240.00. Shipping is $700.00. Every Dealer can have 2 avalable, if they want them. You must sell the first to get the third and sell the second to get a fourth. Hope that helps. Oh, yea the 103 is a 103 (pooch), she will get the front wheels off the ground though.
The only complaint I have is the reverse has a circuit breaker that opens if the Trike is in reverse when the Parking Brake is set. The breaker will also open if the brakes are applied while the reverse is engaged. this prevents damage to the electric reverse motor. Makes sense, only that the breaker is MANUALLY RESETABLE and is located under the passenger portion of the seat. Convenient? Tell me how many times the reverse will be engaged while forgetting the park brake is? Why couldn't it automatically reset when park brake is release. We have a throttle with no cables, but technology hasn't reached a resetable breaker, or convinient location. Here's to the third wheel.
Old 11-19-2008 | 08:25 PM
zoood's Avatar
zoood
Former Sponsor
I purchased just the DFT trike rear. didnt care for the body style or the piece parts as you call em. I also have the EZ steer ordered. I have a trailer body for what use to be called hot rod trailers. Its small like a trailer you pull behind the scoot. But Im using it as the trikes body. The guy before me had it in tow behind his 35 chevy. He added a cut down, rewelded bumper that was rechromed and added 1939 chevy tail lites to it. It does look sharp. All this is going on my 1993 EGC. I like the gearing better on the 5 speeds than the new 6 speeds. Anyways. one of the main reasons I'm doing this build is my product, the V-twin heat deflectors, yes I'm a sponsor in here,.. fits on the DFT Trikes. Its a sales promo for my product but it will also be used for going all over the country. Im also adding a reverse. But built into the tranny. I dont care for the electric one. all it really is, is actually a starter motor mounted in there. I remember as a kid starting a car in gear. no need to relive that experience anymore. the triglides pipe routing doesnt allow you to install the tranny reverse Im getting. Thats why they offer only the electric version.
RJ
Old 11-19-2008 | 10:01 PM
Gutman's Avatar
Gutman
I didn't suggest the "piece part." that was in a nearlier post. The DFT's are awesome. We have built 6 of the. Don't understand a thing else about your post, other than you are building a trike beacuse of "heat deflectors." Not my position to tell you different. I was just trying to clarify. Electric gear, well, you are correct that say's it all. Electric Reverse. Like watching the grandkids in the JI Joe Jeeep in the yard. "Gay." 30k, Give me Power, not a Hair Dryer.
Old 11-19-2008 | 10:38 PM
will2002's Avatar
will2002
If I wanted a trike I would buy the Harley Tri- Glide. If ya get it, and don't want it any more, the resale will be GOOD. And I have "drove" one. They are NICE!!
