Plugs?
Old 11-18-2008, 08:55 PM
ranjon56's Avatar
ranjon56
ranjon56 is offline
Autolites for me, too.
Old 11-18-2008, 09:36 PM
EdwardK's Avatar
EdwardK
EdwardK is offline
I asked the guy at the parts counter about upgrading the plugs and what he suggested. He told me that unless I had upgraded the motor, then there was no reason to upgrade the plugs. He said why change from the ones that were designed to be used in the motor.
Probably crap but an interesting comment
Old 11-19-2008, 06:20 AM
The Old Man's Avatar
The Old Man
The Old Man is offline
Originally Posted by Streetrunner
I run the same plug. Cost me about 1.50 each at advance auto. HD plugs are about 13.00 a pair!
WOW thts a lot of money for a plug set... My dealer charged me $7.and change for OEM plugs and they work very well. Did notice a big difference as I changed them at 15,000 miles.
Old 11-19-2008, 02:19 PM
skratch's Avatar
skratch
skratch is offline
Received 4,358 Likes on 2,536 Posts
Originally Posted by dawg
I run Autolite 4164's for one because they are alot cheaper than the HD pricewise and just as good if not better.
i started running autolites in my sportster and changed them out with every oil change. with the fi on my road king, they last much longer, just changed my set out at 15k, the originals still *looked* good. but i figure for the cost of the autolites, its cheap insurance to change them out every 10-15k. i also like to keep a set on hand during a road trip, just in case.
Old 11-19-2008, 02:50 PM
ms3300's Avatar
ms3300
ms3300 is offline
Default Ion sensing system..??
I hear the new Ion Sensing System (ISS) uses Dilithium Crystals and works in conjunction with the Flux capacitor. While changing the plugs alone should not create any ill side effects, I would be careful not to disturb the Ionization Portal Initiator while tugging on the plug wires.
Old 11-26-2008, 08:15 PM
ssfirefighter's Avatar
ssfirefighter
ssfirefighter is offline
Devil dog, you're speaking my language now. Thanks for the input.
Old 11-26-2008, 08:18 PM
dFREDb's Avatar
dFREDb
dFREDb is offline
The parts guy at the dealership could have sold me the expensive plugs, but he recommended stock. Never had a problem.
Old 11-26-2008, 08:54 PM
edeluxe07's Avatar
edeluxe07
edeluxe07 is offline
Default 13?
last oil change (Jul?) I got 2 HD plugs from the dealer for $6....
Old 11-26-2008, 09:30 PM
Technologist's Avatar
Technologist
Technologist is offline
Same here... HD plugs are cheap (about 3.xx EACH). i have an '02 RK... and am running the higher grade CHampions right now (got on sale for $0.88 each).... cuz I am still tuning in some carb mods. I am going through a set a week (or 2 or 3 sets when doing "chopping")... but will go back to HD standard when done tuning.
Old 11-26-2008, 09:56 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by ssfirefighter
Anyone using different than stock plugs?
Autolite 4163 (one-step colder than stock), about $1.50 each. Runs great and ion-discharge knock sensor works fine. Has been installed for 12k miles--removed recently, looked new, re-gapped, and re-installed. FWIW, stock heat-range plug is the 4164.
There's nothing magical about a V-Twin that dictates using a spark plug that costs $3.30-8.00 each, not even the fact that it is air-cooled. An automotive plug is quite good enough.
Quick Reply: Plugs?
