outer and inner fairing removal
I am seeking advice on what mods to do while the fairing is off.also are there any tricks to putting it back together.I'm painting the inner fairing and planning to highlite the underside of the eyebrows with the color of my pin stripping,any thoughts?Also do I need an alingement tool to reassemble the ignition? thanks in advance
If I had money
This is a perfect time to cut/lighten up the frame, add light weight inverted forks, bore your motor (155 ci or better) than put on components for a blower or turbo, change out your wheels to carbon fiber, upgrade your brakes, take off anything the weighs too much or parts you really do not need ie seat, radio, rubber grips, and replace it with components that weigh less, an air shifter, rear mount pegs & shifter, He-He….sorry!
1. Follow the Service Manual's directions and you'll be fine.
2. Bag and tag parts; also take digital pics.
3. Have a clean space to temporarily store the take-off parts.
4. Have plenty of light; it's dark inside the fairing.
5. Good time to dump the air temp gauge and install the oil temp gauge.
6. Good time to lube the clutch, throttle, and idle cables.
7. Replace the rubber brake lines with s/s; chrome the controls; etc.
8. Etc.
Good luck with your project.
8. Etc.
Yeah. Where does it stop? I am just about ready to start the same thing. So, I installed new chrome mirrors, grips, levers, switch housings & switches, plus a master cylinder.
I haven't even got to the part about removing the fairing yet, which is what I wanted to do in the first place!!!!
Cannon
Cannon
