Passing Lights Fogging Up
Actually the "weatherproof" is part of the problem. When you open the housing up to change the bulb humidity gets inside, creating the fog, and because it is sealed the moisture has nowhere to go.
Take the lamp assembly inside, pull the bulb. let it sit near a heat source for a few hours drying the inside out. Replace the bulb, install the lamp assembly. problem solved.
I don't think that is the problem. Mine are fogged up a little and i never touched them and it is not moisture. Seems to be burnt on the lenses like smoke. I did read an article on how to clean them but forgot what liquid he used inside the lenses. When mine get a little worse i will look it up. Check around because this seems to happen often.
What I did was take it apart, let it sit ine the sun get warm and dry out the lens, reassembled and put a coat of silicone around the bulb socket, no more fog, think it was coming from riding in the rain and washing the bike.
I agree
