New Ultra Setup Advice
I think it makes sense that the oil cooler mainly reduces oil temp when the bike is moving enough for air to flow through the cooler fins. Standing in traffic it would probably help a little since the oil is still being pumped through it, but probably not enough to be significant.
Synthetic oil holds up better at higher temps, which is what I want it for. It may also reduce some of the heat that is due to friction because it is a better lubricant. It could give better mileage though because of the reduced friction. But most of the heat in an engine is due to the combustion process and moving hot gasses out, so I think there would be little temp reduction from synthetic oil.
I need the HD air pump for the rear shocks as well, but can't find it in the accessory catalog.
Link to air pump
At the 1000 mile service point, I plan to switch to synthetic oil in the crankcase, primary and trans. Is that long enough for adequate break in? I have heard some discussion on whether to keep the transmission oil at the 20w-50 recommended by HD, or to go with the 70w-140 that I hear seems to work better. Opinions?
How long are tires lasting on the touring bikes? I hear the OEM '09 rear tire is supposed go longer, but longer than what?
Other than the above, I think I am going to keep it stock for at least the first year and see how everything settles out.
