Fairing crooked
Old 11-19-2008 | 05:01 PM
ptcruiser's Avatar
ptcruiser
I think ateball is correct, I looked at the alignment last night and it looks like the rear wheel is tracking to the right. I did not have time to align it but going to do that this evening. How did ateball go about doing his alignment. Thanks all for the responses.
Old 08-02-2017 | 08:19 PM
Allen Green's Avatar
Allen Green
Stage II
Why are you guys so hung up on dealership service. They are overpriced and most I dont trust to do my front end work. Sounds like first measure distance from fork tube at set point to a fiduciary set point on frame. Do another from lower fork tube to same fiducial. Repeat on other fork tube. Most likely not the same. Loosen bottom tree pinch bolts and hold front wheel while someone sitting on be tweaks the bars. Tighten bolts to spec torque. If it's still crooked go from there. If bars are not straight with top tree, measure it, replace absorbers. Lots of harley you by these days just have crooked fairings.
Hey all of you get a factory manual and talk to us old f--ts that had to work on her own bikes, lots of them know a lot more than you dealer mechanics.
Only reason I might take it in is for an electronic problem to save time, but the manuals have full diagnostics.
Go for it brothers!
Old 08-02-2017 | 08:25 PM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Go for it brothers!
The OP''s problem was nearly nine years ago Two other people have owned that bike since then.
Old 08-02-2017 | 10:48 PM
From_Behind's Avatar
From_Behind
Maybe he's been in a coma, and is playing catch-up!
Campy Roadie (08-03-2017)
Old 08-03-2017 | 04:18 AM
Rustrtal's Avatar
Rustrtal
Well hopefully it's been solved by now. If this bike is still on the road, I would guess it was an alignment issue....
Drtumolo
2014-2023 Touring Models
06-11-2017 03:45 AM
highwayman1224
01-06-2014 02:16 PM
fathertime
06-11-2009 08:33 PM
carlst01
05-30-2008 07:15 PM
FlashG
07-24-2006 05:10 PM
Quick Reply: Fairing crooked
