flashing cruise light
My cruise control light keeps flashing in the off position. Seems after the bike is warmed up after 20 or so miles, it stays out but not always. The cruse control still works, but I cannot shut it off from the switch when the light flashes. Think this is just a bad switch?
Quote from another thread:
In the manual for the 08 Ultra it says that the Engine Idle Temperature Management System comes disabled from the factory. To enable it it says to turn the ignition on, do not start the engine, roll off the throttle for 3 seconds and the cruise light will flash green. The same procedure will disable it by flashing the cruise light red.
Hope this helps........
