License Plate Bracket Help!!
I want to mount the license plate on my Road King Custom lower, like on the Street Glide. I want a curved mount, but I do not like the Kuryaken one because the frame edge is so thick. I want something a little less noticeable. Do any of you know of any other brands, or do I have to fabricate something on my own. Any help would be great!!
Thanks,
Joechief
Thanks,
Joechief
Thanks,
Joechief
Thanks,
Joechief
joechief,
i've looked into this since i have a roadking custom also. the problem with our bikes is that the turnsignal mounts have no holes drilled and tapped into them. the one on the street glide does.
i've found a couple of options, one, take off the light bar, drill and tap a couple of holes to mount the plate (using the stock street glide plate mount) and two, buy a street glide light bar (runs about 80 bucks) and then use the stock mount. and a third option, there was a guy on here who was making laydown plates and was gonna look into making a plate mount for the sg, don't know if he has yet. with any of these options, you are going to need a new taillight, with the white/clear window on the bottom to illuminate the plate.
actually, i had been looking at the kury curved plate holder, instead of the stock street glide mount (which only runs about 12 bucks, but is cheap....) but in the end have decided against all those options, i am thinking of going with a sidemount plate from fireman joes. this will keep the rear fender super clean. use led mount bolts to light the plate and good to go.
whatever you decide to do, come back and post about it. who knows, i may change my mind again....
http://www.bruisersinc.com/Merchant2...y_Code=LICENSE
I have this one and you could cut the outside rail off and just use the backing plate which is curved. It has tabs that go under the turn signal and taillight. I thought about doing this but the rail is starting to grow on me. I looked for a simple curved one also but ended up with only this and the Kury as the only ones found. I guess it's a new product idea someone needs to produce.
![](http://i431.photobucket.com/albums/qq37/flhtc92gmc/DSC00614.jpg)
I do like the location of your plate, but what I really like was your scooter!! What a good looking ride! I really like the leather bags with your color scheme. I took off my leather bags and went to hard bags, I wish I would had seen yours before I did that.
Joechief
Joechief
