Tour Pak Lighting
Old 11-13-2008, 12:27 PM
Craneman14's Avatar
Craneman14
Craneman14 is offline
3rd Gear
Default Tour Pak Lighting
I picked up my new 09 Ultra Classic last month. Really nice bike, but how come the tour pak lighting doesn't work? I have to pay HD extra to activate the lighting thats already installed on the bike? I heard something about a light kit adapter. But where do I plug it into the tour pak harness?- Help
Old 11-13-2008, 12:37 PM
UltraTheo's Avatar
UltraTheo
UltraTheo is offline
Should work. If you can't find a loose connection easily by yourself, take it back to your dealer. Obviously something is not hooked up.
Old 11-13-2008, 12:48 PM
Thirdup's Avatar
Thirdup
Thirdup is offline
Sounds like the quick-connect might be loose. Is it all the lights that are out (run, brake, side LED's)?
If so, open the lid and remove the two acorn nuts that hold the map case/folder on. Slip the tour pak liner out. Look along the bottom and you'll see a pair of wires coming in the front-left base of the tour pak. One is the radio antenna and the other is the power connect for the lights. You'll see a small square connector plugged into the power lead near where it enters the tour pak. Check to see if it's plugged in all the way.
Or take it to the dealer.
Old 11-13-2008, 01:05 PM
wkenddad's Avatar
wkenddad
wkenddad is offline
It all works on my 2009 Ultra.
Must be a loose connector.
The dealer should fix without question.
If not tell them you'll give them a poor review on the survey Harley sends you.
Old 11-13-2008, 01:30 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
.....If not tell them you'll give them a poor review on the survey Harley sends you.
Be sure to threaten them first thing, that always works. Then threaten them with violence and lawsuits. Let us know how it works out.
Sheesh!
Old 11-13-2008, 02:35 PM
Bushy's Avatar
Bushy
Bushy is offline
what a shame that the dealer even let this out of the door!!! talk about crappy customer support
Old 11-14-2008, 09:24 PM
Craneman14's Avatar
Craneman14
3rd Gear
Thanks guys, I'll check the power connector under the tour pak liner. The lower tail and brake lights are all working. The tour pak lenses and bulbs are all in place, but don't work as if they were never plugged in to anything thing?
Old 11-14-2008, 09:27 PM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
Sounds like the quick-connect is not plugged in.
Steve
Old 11-15-2008, 12:26 PM
Craneman14's Avatar
Craneman14
3rd Gear
Thanks alot. You guys were right. The quick connect under the inside cover of the trunk wasn't even connected. I plugged her in and they work.
Old 11-15-2008, 02:13 PM
ezriderpgh's Avatar
ezriderpgh
ezriderpgh is offline
Now that that little problem has been removed from your head you can begin to fill it with thoughts of all the add ons you want!
Quick Reply: Tour Pak Lighting
