now that they work, you can start shopping around for the customizing.
I hit custom dynamics - my side lights on the tour pack now blink as turnsignals
They also have a kit to convert all the tour pak lights to LEDs - with clear or smoked lenses..
Going to get the pucks this afternoon for mine. Just put the King tour pack and ultimate back rest... This task was so easy, I had to look twice to be sure I didn't leave anything out. I'll let you know how the Pucks turned out.
Tom. MN
and it's just the beginning......
for a lot less money easily done with some wire and a few connectors. biggest expense was finding purple wire and having to by a lot more than I needed (3 feet) I already had the run brakes controller in place and just tapped into the wires behind it. both the tourpak back lights and side lights now serve as brake and turn indicators.
Just curious, did you do a pre-delivery walk through on the bike? Was the tour pak made to be detachable? Wonder if the tour pak light connection was just simply not plugged in when it left the assembly line, or if this is a step that was simply missed during dealer prep.
