Two position Tour Pack?
My owner's manual for my '09 UC says that the Tour Pack has two positions. The selling dealer looked at me like I was crazy when I asked him about it. Three people, including a tech, knew nothing about it and didn't think it could be done. Anyone know the answer? Are there two positions and is it easy the relocate? Is the delivered position the extended or the closer position?
I guess you may be talking about using detachable hardware to change the position. I believe the position can be for two up riding or it can be moved up if preferred for one up riding. I'm unsure if you can do both with the 4 point detachable hardware or if the 2 point hardware is needed for 1 up riding.
I'm sure other members will be able to help both of us understand better and my experience is limited to my 09 SG.
Doesn't matter if it's detach or not, there are additional holes in the mounting system to unbolt and move it. I believe it comes in the most forward position. It is not something that can be done on the fly, it requires unbolting and reattaching. If that doesn't give you what you want, I highly recommend the George Anderson Tour Pak relocation kit, search on the forum, you will find it.
The 08s have 2 positions but when I looked at a friends new 09 Ultra I thought it had 3. Look at the bottom of the TP and it should be obvious. As mentioned before it is not a on the fly change it has to be unbolted and moved. As to why
A plus size passenger would probably require a little more room back there especially if when using a rider backrest.
Thanks to all. I know I'm going to really appreciate having all of you and all of your knowlege as an unlimited source of help and information.
The service manual, which I picked up an hour ago, shows two sets of holes in the bottom of the tour pack adding about an inch. Doesn't sound like a lot but I bet it makes a difference. Regards, Jeff
