Clutch adjustment
Ask them to adjust it correctly, or do it yourself, its easy. I'd opt for the do it yourself.
Place bike verticle. Take all of the adjustment out of the cable, so that the lever has lots of play. Then remove derby cover (this is the verticle part, if not oil may run out of the derby cover hole), loosen jamb nut on clutch, insert allen wrench into bolt and loosen , then tighten bolt until clutch pressure is felt, then back off 1/4 turn, want clutch to release sooner? Loosen bolt from 12 oclock position to 10 or leave at 12 instead of 1/4 turn out, You should not have to go past a 1/2 turn. While holding bolt tighten jamb nut. Install derby cover. Remove remaining slack in cable until you have 1/16 to 1/8" play at end of clutch lever to the perch bracket. Your done, now for the fun part.... a test ride. After warm up, roll throttle on in 2nd or 3rd gear and listen for rpm's to increase without the same forward thrust....if so the clutch is slipping or you have megga HP and tire is spinning. You need to back off on the clutch pressure, adjust bolt OUT. My guess is you have it perfect.
Changing of the oil in the primary has a huge affect on how the clutch performs. As well as the transmission oil for shifting. Advise.... change both sooner then HD recommends.
Are you having problems finding neutral when you stop or is it hanging up in neutral between shifts?
