Rg ultra conversion done diy and parts list
Darrin,
The passanger headset does plug into the new harness. It is labled on the harness. The 09 antenna kit was sent to me in error, but I used it anyway. The 09 antennas are shorter than the previous year models and made a little different. I went to HD dealer and got the matching AM/FM.
Thanks,
Draft1
Thanks,
Draft1
At any rate, I am just going to order the factory Ultra Overlay harness, 70160-08A, which has everything already built in. It the same harness that Ultras come with from the factory.
Thanks again for your help. What a great projet.
Darrin
Excellent post and is pretty much spot on with the research i've done so far. Only thing i think you are missing, and maybe im wrong is PN 76440-06 which is the wiring harness that plugs into the non-ultra overlay harness and has the plug on the other end for passenger headset. Do you already have the passenger headset provision?
Im also confused with the cb antenna kit 76400-09, which is for an 09 bike but you said you have an 07? Not sure why you did that is all. Is there some advantage?
Darrin
Darrin
Regards,
DRAFT1
Great Info. I have an O7 Glide and am getting all parts together to set up the CB system. I was told that this link is for flashing the Radio System for the CB, Intercom, XM and so forth. Hope it helps.
http://www.harley-davidson.com/cp/mo...79!-1783475570
My 07 RG looks pretty much like yours. I love it! I put the detachable hardware on thinking that I'd only have the trunk on when I took trips. Well it is so convenient to have it on I never took it off. So if anyone else is thinking about this setup the fixed mount is probably the better way to go. This winter I’m adding the Kuryakyn kit that pushes the tour pak back another 2 inches. I added a Mustang seat this summer and that 2 inches will make a big difference.
Also thanks for the link to the flash info. For some reason I thought the dealer had to do it. I’ll check my software version and and see if there is an upgrade.
Thanks! Again, nice job!
Thanks again
DRAFT1
