Air Horn
I installed the Stebel on my '08 EGC. I Used a Dremmel to cut off the compressor and mounted it under the seat. I mounted the horn under the stock cow bell. It took a bit of trimming and trial and error but it works fine and looks good. I ran hard plastic tubing with black heat shrink over it from the compressor to the horn. There is not much room under the seat of an '08 and I have heard since doing mine that there is more room behind the right side cover but I haven't checked that yet.
There was a thread with pictures about doing this several months ago but I can't find it now.
Check out this post in the "DIY" thread
https://www.hdforums.com/forum/showt...86#post2548586
If you're handy. you can put a Stebel under the stock cow bell cheap
It is the whole unit. Check out the 2nd picture.....I separated the compressor from the horn and mounted it in the cavity in front of the battery under the seat. :-) Mine was an '06 so I don't know about the '09's, but I'm sure one could find a spot to mount the compressor.
Larry
Larry
![Thumbs up](https://www.hdforums.com/forum/images/icons/icon14.gif)
Thanks to all who responded with ideas for mounting the horn. I mounted it in place of the stock cowbell before I read the responses here, I couldn't wait. I hadn't thought of separating the units. I like the idea of putting the horn behind the cowbell and mounting the the compressor elsewhere (in the batwing maybe), I'll check that out when I have some down time. By the way, I love the horn but it scared the @#$$ out of my dogs and hurt my ears when I tried it in the garage. I will be heard on the road now!
Gregm
Gregm
Larry
Larry
Is it me? You separated the horn & compressor and mounted them both in different locations, right? That means the WHOLE unit is not mounted behind the cow bell........Guess we agree to disagree!!!
Received 72,239 Likes
