Throttle Position senser
As I remember, the service manual on my 96 Ultra had a procedure for adjusting the warm idle. Not sure that I can remember all of it. Seems like it was to warm the bike up, adjust the TPS for 1800 rpm, then unplug the ECM fuse for 15 minutes. This may be all wrong. You need the manual. And there may be some other differences with the TC from the Evo. Sorry.
TPS Setting
What are you trying to do, the tps setting is set my a mill volt reading. If you change it take a reading before you move it you may need to put it back to where it was. You need to use two pins inserted in to the connector read the voltage to adjust. If you have not changed any thing you should not need to adjust it. Its very easy too screw it up
burgies08ultra
01-26-2009 02:47 PM
