Wind buffeting coming from below
Old 11-11-2008, 09:43 AM
confused's Avatar
confused
confused is offline
Installed the fork baffle and nothing changed
Wind still comes from the above the lowers and below the fairing
One thing that does help is when I wear a doo rag under my helmet
It keeps the helmet from sliding back on my head
I may try the fork deflectors next
NO, I am NOT buying a Wing
We have all changed something on our Harley's
For those that have changed exhaust
For those that have changed the mapping
For those that have changed the Air Cleaner
You changed what the MOCO couldn't do for you
This is just US fine tuning a great motorcycle to meet our needs
  #82
Old 11-11-2008, 09:50 AM
marcparnes's Avatar
marcparnes
marcparnes is offline
Very well put! I'm going to take a ride up to Cee Bailey's today and take a look at their SSC Shield.
Marc
  #83
Old 11-11-2008, 01:24 PM
Rininhoj's Avatar
Rininhoj
Rininhoj is offline
Default Way back when............
Harley did design a bike in the wind tunnel. Pretty much zero buffeting. Smooth air flow. The FXRT/FXRD
They didn't sell well because they "Didn't look right". Those of us who had them would jump all over it if they built it again, mecanicaly updated that is.
Rini
  #84
Old 11-11-2008, 02:03 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
I told you man,your helmet is the wrong size,if it's comfortable,it's too big.Should be tight with no pain.
  #85
Old 11-11-2008, 06:55 PM
FLoTR's Avatar
FLoTR
FLoTR is offline
can't u just keep ur boots on top of the engine guard?
  #86
Old 11-11-2008, 07:39 PM
shekmark's Avatar
shekmark
shekmark is offline
Yea but it looks real stupid
  #87
Old 11-14-2008, 03:07 PM
marcparnes's Avatar
marcparnes
Default Problem Solved
I now have the combination that eliminates the buffeting to as much as 95%. I have the fork baffle, adjustable fairing deflectors and most importantly, a Cee Bailey's SSC 10" shield. The Cee Bailey's is really what ended up fixing it. I had a 8" Clearview with recurve but the buffeting was still there. I can say now that it is gone! Whew! I just tried a taller 12" Cee Bailey's SSC which was actually quieter with less wind in my face but it was lots hotter and caused pressure on the back of my helmet. The current setup seems to be the ticket. I've already ordered a set of hard lowers which I really don't need now but I think they'll be nice once the cold weather actually gets here (its 90F today).
I hope this helps somebody else with the same problem.
Marc
  #88
Old 11-14-2008, 03:26 PM
confused's Avatar
confused
confused is offline
thanks marc, I have been thinking about bumping up to a 9.5" Clearview
I sit on a sheepskin pad and w/ out the 8" is ok, but I ride w/ the pad
So I may try a blemished 9.5" recurve
  #89
Old 11-14-2008, 03:28 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
I have an 06 Road King FLHRI and had the same problem as some mentioned here with respect to the deflector not helping much on a Road King. However, back in December I put on a Wide Open Customs detachable fairing and it completely went away at that point. So the combination of the fairing and the deflector is great.
  #90
Old 11-14-2008, 03:32 PM
shekmark's Avatar
shekmark
shekmark is offline
I ordered the 9.5 Clearview. The 8 is about 90% where I need to be. I like to look over the screen. I have the 12 inch original on now but it makes the bike handle poorly at high speed.
Quick Reply: Wind buffeting coming from below
