Wind buffeting coming from below
Old 01-02-2009, 12:57 PM
teqsand's Avatar
teqsand
teqsand is offline
Big Kahuna HDF Member
Default I run this
Originally Posted by SpiderPig
Here is a product that does just that. This pic is from Drag Specialties, but Harley has one available as well. They work great, deflects the wind down to the motor vs up over the lowers. You will should be happy with the results, many on here have installed these.
http://shopping.msn.com/specs/drag-s...ork-air-baffle
I run the HD version of this, it works great on my Ultra....
But... I only use it in the winter, being in the mojave desert, if I ride with it installed in the summer I don;t get the proper air flow over the cylinders and the bike runs hotter... Apperatly I've been told the fuel tank acts as a tunnel to channel air to te cyls, this baffel deflects the air and interupts the flow to the cyls....
  #112
Old 01-02-2009, 01:02 PM
beary's Avatar
beary
beary is offline
I noticed that these come stock on the Road Glides.
Beary
  #113
Old 01-02-2009, 01:59 PM
badjustbad's Avatar
badjustbad
badjustbad is offline
Like many others I experience the buffeting on my '08 RKC. I noticed that when I held my hand up while resting my wrist on my knee (sounds kinda gay doesn't it) as if I was telling someone to "stop" it would almost stop the buffeting. Funny thing but it's more obvious on the right side - I have cruise control so I can easily ride with my hand in this position. I decided if I could reduce the wind from below the buffeting would stop so I have been experimenting with ways to reduce, or stop it altogether, with varying degrees of success.
I have the between the fork wind deflector installed but I have replaced my driving lights with the SG version so I can't use the H-D chrome lowers (OK, others have mounted them backwards and they work). In an older thread I showed how I used some clear lowers (glass only) and a windsheild mount to add wind deflectors to my crash bars. With some fine tuning of the location I could totally eliminate the buffeting - in fact it not only eliminated the buffeting it created a large dead air space. I could almost read a map while riding - no sh*t.
I wasn't totally impressed with the look of the windsheild mount and I had to take them off to straighten my crash bar (hit a friggin' deer) so I decided to try something else. I made up aluminum brackets out of aluminum angle to hold the clear glass just below the windsheild. This location isn't as good as the first attempt but it helps significantly. Combined with the hand deflection I describe above I get a dead air space again. if I could mount the deflectors a bit lower I think it would be perfect but turning the bars to full lock just clears the crash bar.
The attached pics should help explain...
Attached Thumbnails Wind buffeting coming from below-deflector1.jpg   Wind buffeting coming from below-deflector2.jpg   Wind buffeting coming from below-deflector3.jpg
  #114
Old 01-02-2009, 03:19 PM
2002flstc's Avatar
2002flstc
2002flstc is offline
I have also noticed the wrist on the knee position creates a dead air space around my head on my '02 softail... almost like riding in the car with the windows just cracked...
A few weeks ago I was on a long ride up the inland valley of CA and experimented with strapping a magazine to my thigh with it extending out beyond my knee... It worked awesome... but looked terrible..
I like your idea and will need to come up with something different as I don't have an engine guard...
I have read this entire thread and find myself somewhat concerned... I should have my '07 FLHX here in a couple of weeks and I guess that I will have to experiment with the peculiarities of the batwing... Oh well, you can fix anything by throwing enough money at it...
  #115
Old 01-02-2009, 05:09 PM
beracing's Avatar
beracing
beracing is offline
Marc
Any shots from the front, side, and from the seating position would be great. If you post an album, I can just look that up also, if that is easier.
Thanks again for all the info!
Bill
  #116
Old 01-02-2009, 05:50 PM
Raaze07's Avatar
Raaze07
Raaze07 is offline
Not that there's anything wrong with that?!?
  #117
Old 01-02-2009, 09:29 PM
nosillyname's Avatar
nosillyname
nosillyname is offline
Thanks for posting the info - very helpful for a common problem.
I suppose it doesnt matter whether you have the batwing fairing or the roadking screen, buffeting can be a real pain in the ***.
  #118
Old 01-02-2009, 10:09 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
That Cee Bailey's SSC windshield looks like it belongs on a Victory Vision. I think I'd rather have the buffeting, fortunately I don't seem to have it.
  #119
Old 01-03-2009, 04:10 PM
marcparnes's Avatar
marcparnes
marcparnes is offline
Originally Posted by beracing
Marc
Bill
Here you go:
Marc
  #120
Old 01-03-2009, 05:52 PM
beracing's Avatar
beracing
beracing is offline
Marc
Thanks!!! Looks great overall, but I would have to get used to the windshield kicked back at me, but if it does the trick, I can deal with it. I had looked at a Klock Werks shield also. My assumption is you drive over the shield, rather than through it. Wonder how it would handle rain....
Thanks again, and best regards!
B
Quick Reply: Wind buffeting coming from below
