AIR/FUEL ratio
Streetrunner: What is your fuel milleage? I ask because that will be a good indicator of whether your bike is rich. If your mpg is 40+, and your engine temps suggest that it is, the exhaust smell is probably the result of the denser air supporting more fuel for the same AFR, so the exhaust has more unburned fuel though the AFR remains the same.
As for a dyno AFR trace going below 13, that's common--at WOT an excess amount of fuel is added to compensate for the relatively inefficient burn of the fuel, especially with carbed bikes which don't atomize fuel as well as EFI bikes. However, as the rpms increase the mixture should be leaned out even at WOT.
That sig pic is old and my SG have gone through a few cosmetic changes since that was taken. I'm to lazy to figure out how to get a new pic on this site. It took me a lot of time to get this one posted.
When I brought it back to the tuner that was the first thing he attempted to change. It didn't change things. Of course it could be him, I don't know.
Here's the funny thing; in the summer I get 41 - 45 and when the weather gets a little cooler I get anywhere from 32 -36. So, yes, the smell = richness. The real question is, "why does it change so dramatically?"
Perhaps it's a problem with the intake air temp reading- faulty sensor or corrupt tables in the tuning file....
I assume you are running true duals? From what I have read, it's the result of exhaust reversion due to the 2 into 2 and the bike will run rich around 2500-3000. It needs to be leaned out in that area, by way of tuning.
My vote would be for the PCIII. Probably because I have a PCIII and as we all know, humans will usually claim that whatever they bought is the best. I have a few different custom maps on my laptop.
1) Local Map
2) Long Cruise Map
3) Altitude Map
I takes about 3 minutes for me to change maps according to my trip plans or my mood. Hook up the USB cable, highlight my map, and click on send map. So easy even I can do it. I don't have ABS so the PCIII is easily accessible and located under my starboard side cover. That's my .02.
1) Local Map
2) Long Cruise Map
3) Altitude Map
