Issues with V&H duals and brake lever
Hello all
I'm looking into adding V&H dual headers to compliment my ovals, but the dealer says I wont be able to install because of my extended reach billet brake lever. They said it wont fit, and if I want the headers, i would have to get rid of the brake lever and go back to stock.
IS this true?
Jay
IS this true?
Jay
I will take a stab here and guess that your shop installs the V&H ovals by whacking on them to get them onto the header. This moves the front header forwards and into the brake lever. How do I know? Because I did the same thing and the header hit the brake lever. How did I fix it? By pulling the header rearwards and then tightening down the mounts when the header cleared the lever
re: Issues with V&H duals and brake lever
I have V & H headers and V & H dual ovals. The 'extended brake lever' will hit the pipes when letting off the brake. The dealer didn't tell me when they installed the V & H set-up. When I changed to the 'billet extended brake pedal' I discovered the problem. The dealer ground off part of the original brake pedal. So, I ground off what was needed to let the 'billet extended brake pedal' rest unactivated without hitting the V & H pipes. I then had the 'billet extended brake pedal' re-chromed.
shoboat90
05-10-2019 03:29 AM
