Brembo front brake conversion project
The stock master cylinder will work fine but, if you current master cylinder has been running DOT5 and the used calipers have been DOT5 you will have an issue unless you rebuild one or the other. You can't just put DOT5 calipers on a DOT4 system without degradation of the seals etc.
Ok thanks. I was planning on either rebuilt or new ones.
