Pic of the failed bearing out my IDS
Well I think you and northside are being rude. I am not a newbie hear. I have used the search boards many times not only on this issue but others. When we hear a new idea on what might be causing a problem with our machines I think it's our duty to post to help out any others who may be having a problem. I think northside was referring to a couple of posts where they had never heard of the IDS but what does it hurt having them ask a question without first doing a search?? No big deal.
I have been wrenching on mostly jap bikes fr the last 27 years, and I know this much.....the jap bikes have been using some type of a rubber insert in the rear hub to cushion the drive lash between the rear sprocket and rear wheel for at least 30 years now.....I have never seen a specific failure of any of the bearings associated with their system. I have seen the rubber bushing insert fail due to drying out or just old age, but that was like after 20 years or so. I am **** about the maintenance on my bikes, and I always do a pre ride check list before any ride over 25 miles. I keep a close eye on drive belt free play, even more when the bike is new due to initial break in stretch. I sure as **** hope my IDS dont get screwed up, because the HD rep will hear my mouth if it does!
I installed an IDS on my '07 FLHTC in Sept.'08 at around 18,000 mi. even though I had minimal tranny noise. It did "smooth" out the ride considerably. I have about 5,000 mi. on it now and keep a check (visually and any abnormal noise) and have been completely satisfied with its performance. Bought it from Zanotti's online, and had them press in bearing before shipping. So far it has been flawless also I have been very happy with the overall quality of my '07. Been doing the maintenence my self and once you know your motorcycle it makes it easier to prevent problems. Also I never wash my motorcycle with any high pressure systems. Feel that it is better for motorcycle all around.
I still believe that the failures being seen were due to install mistakes,either brg or entire kit. This coves axle torque also. One member here had the inside hub chewed up because spacer wasnt installed. HD shouldve installed this brg so someone wouldnt pound the brg in,causing damage right away and may not even have been seated! Some of these failures seem like early installs where dealer either didnt have the tooling or used the old hammer and socket method. This kit was suppose to stop the onslaught of 07 noises and it may be creating something worse. The failures of some wont even make it between tire changes. I still have no problems with mine and it has been looked at twice since first installed but maybe I am lucky or my installation was better than a local shop wouldve done. Those that have failed need to file a safety report.NHTSA is available so use it. Maybe the new SE comp will allow this IDS to eliminated.
It's stamped ***, 559768, CANADA, B08-T, and the H-D part number is also there.
My understanding is that INA has a majority stake in ***.
