Saddle Bags flying open while riding?
Bob
FWIW, I found that my 08 EG left bag developed a rattle at about 8k miles, and it opened very easily. I also found that there is no way to adjust the tension on the spring latch. What I did find though, was there are two small tabs at the botton under the latch that if you bend them upwards just a little bit, they catch the latch and hold it closed. I tweeked them a small amount and found the right amount of tension, Now, the latch is a little bit harder to lift out, but I am certain they will not open, and the rattle is gone.
The lid on the large compartment behind the seat flew up and caught the wind and nearly flipped me. I was picking up my new Ultra and had checked everything over and went inside the dealership to pick up my papers. The mechanic at the dealership had installed an outlet in the compartment previously and had opened it again to check something and never latched it properly. I headed home and the wind was blowing hard and it slamed open about a 1/2 mile outside of town. Those open lids are like a big sail and it nearly blew the bike over. Only time it has ever happen but it taught me a lesson. If the bike has been out of my sight, always check the latches before you ride it.
+1 on the retaining strap. I had this problem and couldn't figure what was going on. I could close my right side bag, then bump it a few times with my fist and the latch would pop up. I posted about it here and found that the retaining strap was sometimes getting closed in the bag lid. If this is happening to you, your retaining strap will probably have a nice straight line in it like the crease in a pant leg. If it does, just put your hand in there as you close the bag and guide the retaining strap away from the lid as it closes. I did this a few times and no longer have the problem. I guess I've re-trained the strap to go the right way.
