Throttle Is Not Closing
On my 09 SG I'm noticing that when I release the throttle it doesn't roll all the way back to the closed position. I have to manually rotate it back the last bit which drops the RPMs down from about 1100 to 900. Also, when I got off the bike this morning at work, I twisted the throttle open and it didn't close at all. Now the bike was off at this time so I don't know if that has anything to do with it, but it does seem strange and the fact that it doesn't completely close when I'm riding concerns me. I know nothing about the new "by wire" throttle. Any thoughts?
Did you put new grips on? Sounds to me like something is binding possibly between the hand grip and switch housing, if not there it would likely be internal in TBW wire inside the handlebar. You could try loosen up the switch housing just a little to see if things let loose, or take it back into the shop.
With the fly by wire throttle control, if you turn off the kill switch with the throttle slightly open, when you restart the bike it will think that is the fully closed position, this will give you a high idle. my 08 does it to me all the time if im not paying attention when i kill the engine. the way to reset it is turn the kill switch to run, with the ignition switch in the off position. without toutching the throttle, turn the IGNITION SWITCH from off to the on position 4 times finishing in the off position. then try to start the bike. sometimes it takes a few times to get the sequence right and it to reset, but it will work. just an idea of what your problem might be. luckilly I had a good salesman who explained this to me cause i did it the first time I turned off the bike.
