Security System...
I’m running with a dealer installed upgraded Harley security system with a pager on my ’09 Ultra Classic. Not happy! Seems you have to actually attempt to move the bike before the system goes off. I think you could remove a saddlebag and walk away without the system going off. Any thoughts, ideas or recommendations. Thanks.
When I first got mine, it was too sensitive because even a hard gust of wind would set it off. Took it back and the security system was replaced. Now, like yours, it takes a pretty hard bump or movement to set it off. I complained about that too, and was told it is "normal". Now, I just lock the bags, tour pack and fork when I leave it parked.
When they changed to the "buttonless" remote fob, the sensitivity adjustment was gone. I don't like it either but if you turn on the ignition switch without having your fob in close proximty the alarm will sound immediately. I had my 2000 RKC sensitivity set so you could just bump the handlebar it would go off. I really miss that! I figure it's better than nothing but wish I could turn it off when I wanted to. The passive arming is a PITA!!
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I doubt that it is as easy as just removing the security part number (68200-07), and replacing it with the non security part number (68920-07).
I suspect that the dealer may have to make some electroic changes to the system, but can't imagine it would cost you more than an hours labor.
lliden
10-30-2007 07:55 AM
