GAS Tank problem HELP!!!
Ok, I finally figured out why my bike was acting up. Insufficient fuel due to clogged and bad fuel filter/strainer. Actually its more bad gas tank.
My bike was telling me that its empty, the guage showing empty, its running like its empty, even reserve (petcock) is not responsive because its empty, its sputtering like its empty, BUT when I finally deciced to empty out my gas tank, I must have drained out close to 4 gallons of gas. What the heck???
So I peaked inside the tank, there I saw that the teflon coating was bubbling and peeling off and those paint chips and rusts were interfering with the fuel flow and quality.
QUESTION:
How to I fix this problem? How do I strip out the inside, clean it and recoat it? How? How? How? Please help.
QUESTION:
I suggest contacting a radiator specialty shop. They usually do gas tank repairs also, and most likely will be able to strip the inside of the tank and recoat it. They'll also be able to pressure test it and check for leaks. I used the do-it-yourself Kreem kit on a tank for a bike I built once, and while I had no problems with it, it looked like stelagtites dangling from the sides of the tank. Don't think you want to try that.
Kleem
I thought of the "KLEEM KIT", but to chicken to even attemp that. I'll check our local radiator shop. Will harley stealership do it?
Ed
Ed
I have used the Kreem kit several times, and if you follow the directions to a T you will have no problems at all. The product has been on the market for over 25 years now....if it was garbage or didnt work, it would have disappeared a long, long time ago. In fact the very first time I used the stuff it was on a old 1974 Honda CB360 that I was puting back into daily service. It worked flawlessly. What you have to do to remove the old peeling coating in the tank now is to put a hand full of nuts and bolts (count them so you know how many have to come back out) in it, and then keep shaking the tank all around until the nuts remove all the loose coating. Then you add "part 2" to the tank and then your just about done.
Heck give yourself more credit than that. It sure aint rocket science......**** I was able to do it!
I've used the Kreem and it worked OK. Had to be real careful as it involves a lot of handling, sealing and rotating the tank.
Also cleaned one out with Acid, then always kept it full of gas to keep it from rusting again.
Never thought about a radiator repair shop, bet it would be better and probably cost about the same.
