Can I run with Xied's/ied's in lieu of a fuel management system.....
Old 10-26-2008 | 12:36 PM
DrPlastic's Avatar
DrPlastic
Default Can I run with Xied's/ied's in lieu of a fuel management system.....
....when upgrading to a stage 1 system? Just wondering if I go with a true duals setup with slip-on's, hi-flow A/C and the Xied's. The Xied's will be richening up the mixture anyhow so I was wondering if this would work?
Thanks
Old 10-26-2008 | 12:44 PM
keithj's Avatar
keithj
im running the xied's on my 07 rkc , with rush slip-on 1.5 baffles , stock ac .the bike runs great ... but in your set up since your going with a hi flow intake i think i would choose something alittle more ... just to be sure
keith
Old 10-26-2008 | 04:59 PM
Mars's Avatar
Mars
If you were just adding slipons then yes. With more air coming in the front then no. I am running O2IED's, stock AC, and WP slipons. Sounds perfect and runs great. I might get a PC3 because I have *slight* popping on decel and if I roll a touch of throttle on then it goes away. The PC3 would eliminate the popping with a +10 on fuel at zero throttle below 3000 RPM. No other reason. I have an 05 FXST with a full Stage 1 and a PC3 and it runs super duper.
Old 10-26-2008 | 09:33 PM
bigjames19's Avatar
bigjames19
I have 07 RKC with V&H big shot duels, XIEDS and stage 1 download with big sucka, its a sweet set up!!
Old 10-27-2008 | 12:28 AM
REALBOB's Avatar
REALBOB
I have drilled holes in the end of the stock mufflers (mainly the right) with the XIED; no other mods. I'm 300+ lbs and my bike usually out performs the stage 1 with other mods. We run'em daily. :-)
08 FLHTCU
Old 10-27-2008 | 04:46 AM
captsam54's Avatar
captsam54
I am running My 08 SG with XIED's, a Doherty air intake, Rush true dual head pipes, and BobVic slip-ons.. Slight decibel pop on a strong downshift.. But other than that my bike is SWEET..!!!
Old 10-27-2008 | 08:10 AM
blueride's Avatar
blueride
Smile Xieds
On my 08 RG, I'm running the XIEDS, everything else is stock. Bike runs great, sounds great and is smooth and fast. I can't believe how good the stock pipes sound with the XIEDS. For $100.00 it is the best mod I have made. Period, end of story.
Harley would have to screw it up with the 09's.
streetbob09
12-18-2009 07:39 PM
harleyrobert4
10-12-2009 03:53 PM
roadking53
06-26-2009 04:54 AM
TennesseeJed
04-10-2009 01:49 PM
DannyZ71
Exhaust System Topics
06-03-2008 03:00 AM
Quick Reply: Can I run with Xied's/ied's in lieu of a fuel management system.....
