Cover woes.....
Cover woes.....
Just want to pass this info on. I garage my bike but wanted an inexpensive cover to protect from dust etc while in the garage. I bought the #71045 Superior grade travel cover from ADCO http://www.adcoprod.com/motorcycle_covers_travel.htm and had a problem. Rode the bike last weekend and put it in the garge to cool off completely (and while it was still warm outdoors) then covered it hours later. Today, pulled the cover to do some work and found the bike was almost dripping wet (the chrome WAS dripping wet.) and proves this cover does not breath whatsoever. They claim to have vents and not to trap condensation, but it just don't work. I'll keep it as a travel cover for when I do overnighters etc but as a dust cover, I'l find something else, lest I have a rust bucket bike in short order.
Just wanted to warn others who may buy this same cover.
This is what I have for my bike when I store it in my shop. It is basically a cotton sheet that is fitted for you bike. I wash it in the washer if it gets dirty. Works great as a dust cover and it breaths.
http://www.motorcycle-superstore.com...ust-Cover.aspx
This is the one I picked up for my ride.....
+1 on the quality. I also have a complete set of their raingear.
Nelson-Rigg Deluxe All Season Cover
http://www.motorcycle-superstore.com...son-Cover.aspx
- The Nelson-Rigg Deluxe All Season Cover made from high-density treated polyester to withstand today's elements and be water-resistant
- Treated with exclusive UVEX to block out harmful UV rays that are the leading cause of color fading
- Air ventilators to prevent condensation and heat shield lower panels
- Four oversized grommets with bungees at front wheel and middle of bike for security
- Soft windshield liner and snug fully-elasticized hem
- Packed into its own attractive carry all
- Not intended for trailering
I use something called the "Goldenrod"....You can buy it at any West Marine store. It's a thin metal rod that you can get anywhere from 18" up to I think 48". I have a 24" under the bike. You just mount it to a 2X4 of the same length, plug it in, leave it under the bike (With a cover on the bike) and it uses very little electricity, is only warm to the touch, and eliminates moisture......Great product and works like a charm......
All you guys and your cover woes at home and in your garage just kill me, you want to make this thing so much more complicated than it has to be, don't get me wrong I use a good quality rain cover when traveling while parked at hotels at night but as much for security as rain. At home in the garage for dust, for years now I use a king size sheet, try it, works great.
