ABS wheel ?
Hog Pro, the difference is the bearing. The bearing has the encoder and the sensor [spacer] rides on it. Other wheel Co. may have the same but mine is Hog Pro.
ABS and wheel replacement
Ab so tooootly right. When you order your new wheel from Hog Pro or who ever make sure to tell them you have ABS brakes. The new wheel bearings should take care of the ABS issue. If you order from Hog Pro. You can order the whole deal. Wheel /tire/balanced/chrome hardware and the ABS bearings. I believe they were a 25.00 option. First rate service and a snap to install. Jack up the bike, remove the axel, slide out the old tire and wheel and replace with the new. Good Luck!
Dynaglide92
Wheels/Tires
03-25-2019 08:01 AM
