PCIII Closed Throttle Values
Just curious what kind of a value you should have when setting the closed throttle position on the PCIII. I recently did this and I believe I have it at 4900. I've been having issues with the bike coughing and stalling when at idle. I'm hoping that I helped this by setting the closed throttle position. Won't know until it stops raining.
The "current" value is actually an algorithm. You do not need to concentrate on this as it can be slightly difference for each bike, you just need to note the % throttle in the main screen which should read 0% at idle.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
