o2 sensor eliminators
10-23-2008, 06:44 PM
Okay, so I found the sensors(with FuelMoto's help). Next question - do you just tape the remaining loose end after you insert the eliminators?
Thanks,
r0ckie
07 Ultra, PCIII, V&H Slip-ons, SE airbox
10-23-2008, 06:56 PM
Loose ends.
Yep, tape 'em with electrical tape, or let them flap in the breeze. It would have been good if Dynojet had added a couple little rubber caps.
10-23-2008, 06:59 PM
o2 sensors
Thanks, Steve. I'm gonna see if I can get a couple of caps from harley. There's a capped connector behind the throttle body that's the same shape & size.
10-23-2008, 07:09 PM
Or you could remove the 02 sensors completely and plug the holes.
10-23-2008, 07:30 PM
I used zip ties. Just tie them where they will be out of the way and not get full of crud.
djwhaley
11-17-2013 03:28 PM
skratch
05-29-2008 01:52 PM
cornishman
17
02-21-2008 02:06 PM
Scootr
11-09-2007 09:12 PM
tunaman
07-05-2007 06:39 PM
