Looking for a inexpensive wheel chock for 08 Ultra
Hello All.
I am looking for an inexpensive wheel chock to use in my garage for my 08 Ultra. Would like to be able to drive it into the chock and get off. I like the Condor but damn, it is expensive. I would use the chock to save room and to also perform maintenance. I have a lift but the lift is in the way of draining fluids, thus needing a chock.
Let me know if you've found one that works.
I borrowed a trailer from a friend that had one of these mounted on it:
http://www.motorcycleramps.com/black...heel-chock.htm
It worked perfectly for my 96 UC. Drove it on and got off the bike and then tied it down. Might need a little tack weld to replace some bolts to use in a flat surface, but it should do nicely.
