Amsoil products
Amsoil products
I am currently trying to change the oil in my 05 Classic. After using Amsoil products in the past of course I wanted to continue. After picking up the oil and filter while trying to replace the existing filter I noticed the new one is slightly smaller in diameter. The threads are the same just the filter is smaller. According to the Amsoil rep they changed the size of the filter to make it more universal in order to be used with more applications. Do I risk it and install the smaller one or purchase a different brand name like HD to get exactly the same size as original? thanks for the help.
It's a full synthetic oil, just like HD's magical synthetic elixer but better. If won't cause any problems, it doesn't cause leaks, it doesn't prevent an engine from breaking in, it doesn't react with natural oil and form crystals in the engine, or any other wives tale that someone may have told you. It will work just fine
I've used Amsoil for some time now, since the early 70's in all my toys domestic or german without any problem. from what I've read comparing Amsoil filter to others it out performs all of them, the same with the oil. the smaller size filter actually is a benefit I can use a 100% cotton strap wrench to remove it and give it that extra 1/4 turn during installation. recently, on my 5K oil change I used the 70W/140 in the tranny it did away with the noise in 5th gear and finding "N" is easier.
