Accessory Switch Hot with Ignition Off?
I have searched and read about the accessory switch but have not found the answers I was looking for. I am trying to hook up a few LEDs to use as parking lights when the bike is parked with the ignition off and a little added visibility riding at night. I was under the impression that the accessory switch was hot in the on position with the ignition off or on, but that does not seem to be the case.
By bike is an '08 Street Glide with ABS & spots, if that makes a difference . The Owners Manual indicates that the accessory plug is under the left side cover. Under my left side cover there are 2 plugs one of which I believe is the data port. The one that the OM indicates is the accessory plug has only 3 wires going to it. The wire colors don't correspond to the colors in the Service Manual. In addition I have an accessory plug by the battery that is hot in the on position with the ignition on only. The wire colors match what the SM indicates for the accessory plug.
Is there anyway to utilizes the accessory switch to power the LEDs with the ignition off and what the hell is that extra plug under the side cover?
The male connector is buried in the bunch of wires and connectors in front of the battery. It has a removable rubber plug on the end. You need the female connector and pins if you want to go that route. The dealer has both.
Yes, the accessory switch only works with the ignition on.
Extra plug is for the security siren.
