security system
RE: security system
I have the complete setup on my Dyna Wide Glide, including pager. The system is made by Delphi; same company that makes parts for GM. Delphi is a spin-off of GM. The systems work great. I am amazed at the options that allow for different set-ups. One can select the alarm for storage or transport so that the alarm doesn't drain the battery or set-off with the movement in a truck. You can enter a secret code to turn off the alarm using the turn signal buttons. The sensitivity can be set for the motion sensor. The alarm can be set to auto-on when the ignition switch is turned off. The pager can be set for audible or vibrate or both.
My bike had the basic alarm with the siren and I installed the Siren-II and programed the Remote Pager. I think most of the later bikes have the wiring, and some may need to install the alarm system bracket under the seat.
RE: security system
OK what is the trick. Or has anyone done a write up on this yet. I put in the alarm while I am waiting on my smart siren II and pager to come in and everything seems to work fine, but when I start the bike it just shuts off. When I take the TSSM out and put the stock TSM back in all is back to normal.
Jeff
Jeff
RE: security system
Jeff,
I have not read thru them, but I remember reading some other posts on this that people that have issues with installing it them-self found the answers in the Do it your self General section. I hope this helps.
Bob
Bob
ORIGINAL: jskwarek
Jeff
Jeff
