"Knock" on start up
"Knock" on start up
OK everyone, I've got an '08 FLHR with 9700 miles on the clock. In the last 1000 miles or so, I've noticed a "knocking" sound when I first fire up the bike. I also hear the "knock" at a certain range of rpm's until the bike gets warm. After the bike is warm, I don't get the "knock" on either start up or at the range of rpm's when the bike is cold.
I'm afraid many of you are going to tell me it's "normal", but I don't think it is because I've got two friends with '07 Kings and another with an '08 Heritage and their bikes don't sound like my knocker. It's hard to describe the sound, not saying that it sounds as bad as a rod knock, but nonetheless, the knock is still prevalent. Any suggestions?
"I also hear the "knock" at a certain range of rpm's until the bike gets warm. After the bike is warm, I don't get the "knock" on either start up or at the range of rpm's when the bike is cold." You said right there! Takes about 5 minutes at start-up to warm-up to op temp esp. the O2 sensors (600 degrees F at sensor). Do not hit your throttle after starting cuz it takes the bike out of warm-up/enrichment table to the idle table (ECM thinks you're ready to ride). Operating temperature (heat) aids in the combustion of fuel.
