oil temp and lowers???
Two issues really. What temp should the oil be? Just put in the new oil fill/temp stick and it is a bit troubling. Second, does the installation of lowers affect the cooling of the engine? In my case it really appears to be noticeably hotter since I put the lowers on. My issue or truth..
J
J
I see you're riding a Road King so either your talking about the slip over lowers or the vented ones. My Ultra has the vented ones, and when the vents are closed, the oil temp rises a bit as evidenced by a slight drop in oil pressure. I don't have an oil temperature guage,but oil pressure will indicate whether the oil is hot or not. Normal pressure on my bike is 32 psi. It will drop to about 28 on hot days, or cooler days with the vents closed. Hope that helps you some.
Most of the posts I've read say 220 is about average for a non oil cooler equipped bike, with excursions to 250 or so in heavy traffic on hot days. Most of us run Synthetic oils which will endure up to 300 degrees without losing lubricity.
My experience with having recently installed fairing lowers on my '04 EG is that the temp goes up slightly at cruising speeds due to less air flow at the rear cylinder--probably less than 10* based on the HD oil temp gauge with the sending unit in the oil pan.
You could have the ECM adjusted to deliver just slightly more fuel to the rear cylinder since the additional gas will cool the rear cylinder.
With a good synthetic oil, I wouln't worry about the temps unless you are in the desert with ambient temps over 90*.
Read a great article in American Iron magazine (December?). Basically discussed whether you should use an oil cooler or not. The take away was that EVERY Harley should have an oil cooler (except VRod)... and that the best one to get was a 10-row Jeggs cooler. In fact, in the article, the guy had installed 2 of them on the bike!! Not sure I'd go to that extreme, but it did convince me that I was going to install one this winter.
