TWR Missing link install
TWR Missing link install HELP??
UPS dropped it off today while I was gone. Got home this afternnon and decided I'd tackle it. First off the unit looks A-1..very nice piece. Anyway followed the directions to the letter (I thought). For the life of me I could NOT get the exhaust pipe out of the way. Pipe was loose at the jug, all heat shields were removed as directed, all clamps loosened or removed. mufflers dropped, passenger board removed. That thing would not go down out of the way. What did I miss? I got it installed but it was a serious PITA with the pipe in the way. Have read lots of posts here that said they installed it in a hour or so. I would have sure liked to have one of those guys helping me. Anyway, all buttoned up and waiting for a test drive. If this thing works as good as it was made I will be in for a real treat.
Ken
Ken
Ken
Ken
Anyway, sounds like you got it on. I'm sure you will be happy with the way your bike handles. Be sure to post a report.
This thread might help others who read this and need help:
https://www.hdforums.com/forum/showt...g+link+install
Steve
Ken
Ken
Did you remove the bracket under the trans? That is the most important one. If your using Rinehart TD's then there is a shim you need to put in between that bracket and the pipe itself. I installed mine in 1.5 hours from the time I opened the box to the time I was washing my hands.
I like the TWR, and I also like the Ride Str8, and the Bagger Brace all of these have a good design as far as I am concerned. I got the TWR for less than the others thats why I bought it. My 08 Street Glide is like a new bike now. No more of that feeling like your rear tire is going flat, or the wallowing through fast corners. The bike just feels much more stable and predictable. I should have bought it the day after I took delivery!
Ken
Ken
I got mine last week and had the same struggle with the stock pipes. The instructions say to have another person push the pipe out of the way while you bolt on the bracket. Unfortunately it was just me, so it took a little while. No way could I fit my torque wrench on the lower bolt with the pipe in the way. Other than that the install was straight forward and the results excellent. I've never experienced "the wobble", but always felt the bike was loose. Wind coming off big rigs always made the ride interesting. With the TWR installed, the ride felt really solid. I purposely got behind a few trucks and did not get pushed around as I had previously. It's like a different (better) bike. Overall, the performance envelope was significantly expanded with this upgrade. Color me satisfied.
Paul
Ken,
Paul
Paul
I had my wife (110 LBS) pushing down on the back with no success. Then I tried it (285) and I did no better. Was to the point I was afraid of breaking something. Please understand that I am NOT knocking the product in anyway. I was just wondering how some guys zipped right thru the install and I had such a hard time.
Steve
Did you loosen the tranmission clamp on the rear header pipe. If you don't do that, the rear pipe won't drop down. I used a long extension and 1/2" wobbly socket to remove the nut from the stud. I also loosened the exhaust clamp that holds it all together. Hope this makes sense to those that are having a hard time. Let me know.
Steve
Steve
I asked him the same question like 4 replies up......he never said if he removed the bracket at the trans or not........oh well. It only took me as long as it takes to loosen up the RS exhaust and install the brace....I guess about 1.5 hr. with plenty of phone calls, and cigarettes and coffee brakes.
