09 UC, 36 front 40 back with nitrogen. Runs cooler, less maintenance and no pressure variation when hot or cold. Can do a whole summer without loosing air pressure. By far, the single most critical factor for maximizing tire life and minimizing the chance of catastrophic tire failure is maintaining the proper inflation pressure for a given tire size and load. Nitrogen allows a tire to retain more of its original properties
D402 front, 37psi. E3 rear, 40psi. Check your tire-pressure gauge, as it's probably not correct. Both of my pencil gauges read 2# low, so I inflate the tires accordingly.
