I don't have any fancy scanner, just wondering how I could clear the codes, Thanks
Assuming 02 is the same. Start bike 50 times and 51st start should be cleared if repairs were made. Or take to dealer. These are the only 2 ways I know of.
Not sure if it's the same as an automobile but since that's where the ecm's were derived from try disconnecting the battery cables and holding them together for 10-15 seconds. That'll drain the memory in the ecm and erase the fault code. Works in cages.
if I held the battery cables together I would really have problems
