tuner help...?
Old 03-31-2006 | 07:30 PM
Mitt's Avatar
Mitt
Default tuner help...?
Have an 06 RK - want to put on some Kerker slip ons and I understand I need a tuner to make this right after the install what's the tuner of choice around here...? Easiest to use, easy on the wallet...?
Old 03-31-2006 | 07:58 PM
twoseas's Avatar
twoseas
Default RE: tuner help...?
You could try the TFI/DFO. If you do a search there's plenty of writing on this very subject.
Hope this helps.
Old 03-31-2006 | 08:07 PM
Luck Dragon's Avatar
Luck Dragon
I used a Power Commander, A/C Ness Super Sucker with k&n filter, Super Trap slip-ons, and new 25' injectors, dyno'd results 78hp & 77.5 tor. Runs great. Real improved mid range.
2006 Ultra Classic
Old 03-31-2006 | 08:23 PM
bountyhunter's Avatar
bountyhunter
Yep, Power Commander (PCIII), dyno tuned. Costs a few $$$, well worth it to get the most out of your package, plus the performance you deserve.
Old 03-31-2006 | 08:28 PM
Mitt's Avatar
Mitt
ORIGINAL: bountyhunter
Yup - I do deserve it, I sure do ...
Thanks for your help Gentleman - now it's time to go Ebay shopping for a tuner I believe it's number 807-511 unless someone here knows a good place to pick one up???
Old 03-31-2006 | 08:58 PM
Matt8643's Avatar
Matt8643
I would also recommend the PCIII. Myself, and quite a few others on this forum have bought the PCIII from Fuel Moto USA. They will pre-program it for you to your specs, so it is ready for installation as soon as you get it! I installed mine myself in about 30 mintues. Runs great right out of the packaging and they have the best prices I could find.
Here is their website:
http://www.fuelmotousa.com/
Old 04-01-2006 | 09:25 AM
Mitt's Avatar
Mitt
Thanks - great reference...
Old 04-01-2006 | 11:39 AM
bay13's Avatar
bay13
If you have decided on the PC III then I'd use the below link. They double the warranty, and actually talk to you so they can pre-load a program in the PC so the bike will run until you can get a good Dyno tune done.
(What Matt said)
Old 04-02-2006 | 10:10 AM
Mitt's Avatar
Mitt
O.K. FYI - I thought about this and decided to go to Harley and get a one shot map chip installed cause more than likely the slip-ons and air filter will be my only mechanical changes.
Talked to the Service manager here's what he said - 2006's can not be simple chipped anymore Mother Harley has decided to opt out of the programming business. Therefore, there is no other choice but to buy a tuner and this Dude said their dealership has now got into the business of installing Power Commanders...
matt85
05-16-2018 08:35 PM
scooper321
12-05-2014 02:52 PM
pv123
03-24-2013 03:38 PM
oneroadking
06-08-2012 07:40 PM
Jessie
03-08-2009 05:48 PM
Quick Reply: tuner help...?
