Electraglide spotlights
OK, So the stock spotlights cast good side light and some improved closeup visability (just enough so you can see the bunny you are about to run over). What sources are there for a brighter and whiter replacement bulb assembly? This sure looks like a sealed item to me so no replacement "bulb only" kind of improvement. Somebody must make a upgrage sealed lamp.
Joe
Joe
Received 7,826 Likes
RE: Electraglide spotlights
Harley does. The below lights are the ones I have and I installed Piaa bulbs in them, they work great.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Joe,
I replaced the stock sealed lamps with the halogen bulb set. I find using a pair of 55w Hella yellow stars was a good combination. The beam pattern really lights up the road to either side and forward a good 100 yards. The softer yellow is less distracting to close up objects than bright white. so i don't have a hard time focusing down the road (an old timers thing). The slight yellow is very helpful in the rain, and an added plus is the reduced dazzle for oncoming traffic.
Tom
Tom
1 Post
Ditto!
ORIGINAL: tcfamy
Joe,
Tom
Joe,
Tom
Joe,
J&P Cycles has an aftermarket replacement bucket that will accept an H3 bulb that can be replaced as needed. The replacement lenses are $40 for clear, similar to the stock ones. p/n 330-433. I just ordered a pair for myself for an 05 ultra. I replaceed the stock headlight bulb with a sylvania silverstar #9003ST and it lights up the night.
Andy
Andy
